I am getting the following error: ERROR: nextval: reached maximum value of sequence "metrics_id_seq" (2147483647).
The maximum ID for metrics is slightly lower than this value, but the sequencer seems to grab a block that puts it over the maximum state. In my metrics table, I see large gaps in the metrics ID each time I add a new server (host), service, portal, etc. I cleaned up some old components I did not need, but the sequencer does not seem to reuse old, unused IDs.
It seems that I either need to renumber all my metrics IDs and the corresponding child tables or set this ID to a much higher number. Has anyone else encountered this issue and found a solution? So far, I have received no help from the ticket I opened, and I do not want to touch the database without ESRI approval.
