I have created a map with simple Topographic basemap and have OAuth set up (I can verify that it works correctly). Also, I don't set 'ArcGISEnvironment.apiKey' variable.
I expect that auth challenge is raised and basemap is loaded after that. Nevertheless, I get the following error in console:
flutter: [E] 22:25:29.502337 Unhandled Loadable ArcGISMap load error: ArcGISException: code=22; HttpException: Failed to parse header value
If I set apiKey, everything works well.
This can be reproduced using Authenticate with OAuth sample. Just remove apiKey in 'main.dart' and change 'onMapViewReady()' function to the following:
void onMapViewReady() {
final map = ArcGISMap.withBasemapStyle(BasemapStyle.arcGISTopographic);
// Set the map to map view controller.
_mapViewController.arcGISMap = map;
Could you please clarify how can I use OAuth only (without API key) for loading basemap?
I am checking via iPhone 15 simulator w/ iOS 17.5. Haven't tried on Android ones.
ArcGIS Flutter SDK version is 200.6.
