I have some data coming through a Velocity RTA. When the RTA Detects an INcident (Started or Ongoing) the data is sent through a Stream Layer and appears on a Map which is used in a Dash Board and an Experience Builder App.
Started and Ongoing events render correctly, but when the Incident transitions to Ended and then disappears from the Stream Layer completely, the Point that was last rendered seems to stay on the Map until reloaded!
I have tried Filtering on the IncidentStatus but that does not seem to be the answer.
TIA, for any pointers/direction.
