Using Pro 3.2 on a Windows 11 PC.
I normally work with three monitors. One I setup in portrait mode with tabs like Catalog, Geo processing, Attributes, etc. in the top half of that monitor and on the bottom half of that monitor I place all my open attribute tables. Today I am working with a different setup and only have two monitors. When I select to open a layer's attribute table it does not show on either monitor even in part. I tried setting my display to only use one monitor because that would normally force all windows to open on that monitor. The table window still doesn't show. I tried reset panes also with no luck. Does anyone have an idea on how I could force the window to show? In projects I saved with the table windows docked to the bottom of the main window, I can still see them.
