I have two datasets that I am joining where one is the primary dataset of features with geometry and the other is stemmed from a Survey123 form that contains entries for active restrictions to the primary dataset (parking related for our municipal airport).
I use the FeatureSetByPortalItem function in Arcade to pull in all features for the primary feature and the survey feature. I want to use the Filter function to filter the survey feature to only retain active restrictions based on the rest_start and rest_end date fields that indicate when the restriction is to begin and end. I know that in the Filter function you use SQL syntax to apply the filter you want but I can't seem to get mine to work. What am I doing wrong here? See below a snippet of the code used to pull in the feature set and the end of the filter function where I try to apply the SQL query. It seems to throw an error related to the GETDATE().
var restrictions = Filter(FeatureSetByPortalItem(Portal(p), '<ITEM ID>', 0, ['aircraftparkingnames','rest_type','rest_type_other','rest_name','rest_start','rest_end','rest_desc'], false), 'rest_start <= GETDATE() AND rest_end > GETDATE()')
