Hello, I am trying to copy the common print widget and want to customize it a little. I found it in the client/dist/widgets/common folder, copied the src folder and manifest.json, icon.svg, config.json to client/your-extensions/widgets/CustomPrintWidget folder and changed the manifest file to match the folder name.
Now I am getting an error when trying to build the widget:
ERROR in ./your-extensions/widgets/CustomPrintWidget/src/setting/component/report-template-setting.tsx 14:0-69 Module not found: Error: Can't resolve 'jimu-ui/advanced/app-item-selector' in 'D:\Users\pratybos\Desktop\ArcGIS Experience Builder Dev\ArcGISExperienceBuilder\client\your-extensions\widgets\CustomPrintWidget\src\setting\component' resolve 'jimu-ui/advanced/app-item-selector' in 'D:\Users\pratybos\Desktop\ArcGIS Experience Builder Dev\ArcGISExperienceBuilder\client\your-extensions\widgets\CustomPrintWidget\src\setting\component'
To my understanding this error is shown because the widget doesn't know where some modules are. How do I config it so it finds the necessary modules? Editing dependencies in manifest doesn't seem to work. Do I need to use the loadArcGISAPIModules function? Or is there some better way to point where the module is stored?
Thanks in advance, all help is appreciated.
