I am using ArcGIS Enterprise 10.9.1
I have a javascript application that is on another domain than the portal / web adaptor.
I want to authorize that application and display the login form in an iframe but I got the following error:
Refused to display 'https://myportaldomain.com/' in a frame because it set 'X-Frame-Options' to 'sameorigin'.
In the javascript application I am doing like this:
<iframe id="my_iframe"></iframe>
var myIframe = document.getElementById("my_iframe");
myIframe.setAttribute("src", "https://myportaldomain.com/portal/sharing/rest/oauth2/authorize?client_id=xyz123&redirect_uri=https://myappdomain.com/myapp&display=iframe&response_type=code");
myIframe.onload = function() {
//here I test if the code is available in the iframe url parameters
I have tested this authorization steps when the application is on the same domain than portal and it works.
How can I make it works cross-domain?
