This week, after updating ArcGIS Pro to version 3.4.0, when I attempt to export a selection of points collected with Field Maps in an ArcGIS Online hosted feature layer to a file geodatabase feature class, all of the exported points show up in a single location (the location of one of the exported points). This occurs with both a right-click on the layer name (with Data: Export Features), and also with starting directly from the Export Features geoprocessing tool. The other attributes appear to maintain their original values - it is simply the location that gets modified.
I have been using this workflow frequently in the past (exporting a subset of collected points to a project-specific geodatabase), and the points always exported to the correct location, even if specifying a new coordinate system. I did not notice this "consolidation" until this week, which just happens to coincide with my v3.4.0 update.
When I tested this with other ArcGIS Online point data that was NOT populated using Field Maps, the points exported correctly. Likewise, when exporting selected points from a local source (file geodatabase), the points also exported correctly.
I am attempting to find ArcGIS Pro installations within the organization that have not upgraded to 3.4.0 to see if it is version specific. Has anyone else encountered this issue?
