I am testing parallel processing of arcpy using Python's multiprocessing package, however, I am running into issues when trying to serialize ArcGIS Pro objects. I was wondering if anyone could suggest a better option to my workflow.
My current workflow is to loop through each layout in a .aprx, extract some info from map frames (i.e. data layers, broken links, etc.) and make some changes to layout (i.e. relink map frame on bottom right to a global map). At the moment, I use `arcpy.mp.ArcGISProject` in my worker function to open a project, select a specific layout, then extract info for that layout. This works but seems to take pretty long (~ 12-15 minutes for a batch of 10 layouts on a .aprx).
Below is test code I hope to get running, which mimics my desired workflow/code.
import os, sys, tempfile
import multiprocessing as mp
import arcpy
def execute(layouts):
# Init pool
pool = mp.Pool(processes=mp.cpu_count() - 1, maxtasksperchild=10)
# Use apply_async from multiprocessing
jobs={}
print("starting multiprocessing...")
for lyt in layouts:
jobs[lyt.name]=pool.apply_async(worker_function, [lyt])
pool.close()
pool.join()
for lyt_name,result in jobs.items():
try:
result = result.get()
print(result)
except Exception as e:
print('{}\n{}'.format(lyt_name, repr(e)))
# > HCTTiv11027v04 NOCAL Range Complex
# > TypeError("cannot pickle 'MappingLayoutObject' object")
# Below does not work either
# from concurrent.futures import ProcessPoolExecutor
# print("starting concurrent futures...")
# with ProcessPoolExecutor() as executor:
# results = executor.map(worker_function, layouts)
# print(results)
# for r in results:
# print(r)
def worker_function(in_lyt):
# Do some "fake" work
print("worker function on :", in_lyt.name)
return f"worker function on: {in_lyt.name}"
if __name__=='__main__':
# Get params
fdir = r"C:\path\to\dir"
aprx_fn = "test.aprx"
print(aprx_fn)
# open aprx
aprx_proj = arcpy.mp.ArcGISProject(os.path.join(fdir, aprx_fn))
# get a list of layouts to pass as param to function
layoutList = []
print("layouts:")
for lyt in aprx_proj.listLayouts():
print(lyt.name)
layoutList.append(lyt)
print("executing...")
execute(layoutList)
Thanks in advance
