I am trying to publish a feature layer to AGOL through python. I have a script and have successfully done this many times with this script in the past few weeks. All of a sudden, I am getting an error that says "Exception: Overwrite unsuccessful. Check that editing capabilities are enabled on your service."
When this is happening, a File Geodatabase is published to my AGOL, which I can manually go click on and hit "Publish" and get the feature layer I was originally trying to get.
I've tested on a few different datasets (some from my local computer, also tried to grab a simple feature layer from AGOL and republish), but I am getting the same error every time. I have updated the arcgis module and all the modules I am using in my script currently (although this error came up before I did any updates).
Just wondering if anyone else has experienced this lately and/or if there are any solutions?
I am able to otherwise successfully pull in feature layers, truncate, update, etc. But just running into this issue when initially publishing?
feature_layer = census_map.spatial.to_featurelayer('Test')
Thanks in advance for any help or advice.
