i am trying to write a simple script to append a few large feature services into a local feature class.
The feature classes have many more records than the MaxServerRecords so i am splitting them up into smaller chunks and processing them.
i keep running into issues with the append failing, it will work sometime and not others, i get the following errors, "500 error the server threw an exception", "Cannot read Table" and "Unknow error has occurred contact ESRI".
my scripts all run fine with small numbers of features.
features that will work when run with small features will sometime fail when run in the large batch
i am using the url of the feature service as input for the arcpy.Append_management(), is this the best way to do it?
i found an old blog that talks about using a FeatureSet?
