Some help on this please, Thanks
Script work works great for finding Facilityid numbers not found in “b” or final =a-b. But to make the script more useful an additional field or
“NAME” should be printed in conjunction with the Facilityid number or “FACILITYID & NAME” and this is where I need some help. The “NAME” field contains text (ex:“Redondo Tank”) and is difficult to add or subtract and the set function works perfect for my task.
Larry Adgate
# Import arcpy module
import arcpy
# Local variables:
Index = "C:\\Projects\\UpdatePlantFacilityIndex.mdb\\FacilityIndex2013"
Arden_ns = "C:\\Projects\\UpdatePlantFacilityIndex.mdb\\UpdatePlantFacilityIndex\\Network"
a = set(r[0] for r in arcpy.da.SearchCursor(Index, ["FACILITYID"]))
a1 = set(r[0] for r in arcpy.da.SearchCursor(Index, ["NAME"])) #Addition field data to accompany FacilityID
b = set(r[0] for r in arcpy.da.SearchCursor(Arden_ns, ["FacilityID"]))
final = a+a1-b
print "Arden System Discrepency: {0},".format(", ".join(sorted(final)))
#error Message: final = a+a1-b
#error message: TypeError: unsupported operand type(s) for +: 'set' and 'set'
