I am trying to save the query results as a file gdb using python (arcgis api for python) but keep getting this error:
"Failed to export to File Geodatabase: The Product License has not been initialized."
I googled about it but could not find any solution.
I do appreciate any help.
Here is my code:
from arcgis.gis import GIS
from arcgis.features import FeatureLayer
from datetime import datetime
import os
try:
# Connect to Portal
org = '**unspecified**'
username = os.environ.get('AGOL_SCRIPT_USER')
password = os.environ.get('AGOL_SCRIPT_PASS')
# Initialize GIS object with license check
gis = GIS(org, username, password)
# Check if the GIS object is valid
if not gis:
raise Exception("Failed to initialize ArcGIS Online connection")
print("Connected to ArcGIS Online")
# Define feature service and query parameters
feature_layer_id = "**unspecified**"
# Get the feature layer
feature_layer_item = gis.content.get(feature_layer_id)
feature_layer = FeatureLayer.fromitem(feature_layer_item)
# Define query parameters
where_clause = "requestorCode = 'R7'"
out_fields = "*"
# Perform the query
query_result = feature_layer.query(where=where_clause,
out_fields=out_fields,
return_geometry=True)
# Check if there are features returned
if not query_result.features:
raise Exception("No features matching the query criteria")
# FGDB name
file_gdb_name = "test.gdb"
# Define the save location for the File Geodatabase
gdb_path = f"/arcgis/home/{file_gdb_name}"
# Save the query result to a File Geodatabase
query_result.save(gdb_path, f"{file_gdb_name.split('.')[0]}")
print(f"Exported queried output to File Geodatabase: {gdb_path}")
except Exception as e:
print(f"Failed to export to File Geodatabase: {str(e)}")
