We came across this inconsistent behaviour:
ArcSDE with Enterprise Geodatabase Feature Class:
We've got multiple schemata with various vector data, e.g. schema "xyz" with data "test". These data are periodically updated by its provider, who changes sometimes also the associated data design. Meaning some attributes are deleted, other attributes are added and the geometry is almost always updated. To not have to update every map which uses that data, we will replace the old "test" data with the updated data, which will also be called "test". The old "test" data will be deleted from the ArcSDE. This approach is well established with our clients.
PostgreSQL with Query Feature Class :
Recently, we tried the same approach with a PostGIS / PostgresQL Database with Query Feature Classes. Same schema "xyz", same data "test". If we replace the test-data with updated data with the same data design, it works fine. However if the data design changes (e.g. attribute deleted), the data can be displayed in ArcGIS Pro (currently 3.3.0), but the attribute table cannot be opened. the following error message is displayed: Attribute column not found.
We would like that it would be possible to update the data (regardless of the underlying data design) as it was possible with Enterprise Geodatabase Feature Class in ArcSDE.
We assume the issue originates in the Query (see Layer Properties >> Source >> Data Source >> Query) sent to the DB, which is currently
select objectid,attr1,attr2,attr3,...,attrN from xyz.test
it lists all attributes (attr1,attr2,attr3,...,attrN) instead of using the asterix (*). if the query is manually changed so that the asterix is used, the attribute table can be opened. However the query cannot be changed a priori or per default, which makes this workaround not a usable workaround.
We would like to propose, that either the same data update behaviour is used for Query Feature Class / Postgresql-DB as it was for Enterprise Geodatabase Feature Class / ArcSDE or that the used default Query can be defined inthe database or the options.
