Is anyone else having problems with PythonWin running geoprocessing commands? Pythonwin intermittently crashes on arcpy.env.workspace, arcpy.Buffer, or other tools. Has anyone solved this issue yet? Here's a video to show you what I mean:http://screencast.com/t/EbXKrGP6HIn the video, closing PythonWin between each test:test 1: run script (with running man) -- it crashestest 2: run script with step through -- it workstest 3: run script with running man -- it workstest 4: comment out setting workspace in script. run script (with running man) -- it crashestest 5: workspace still commented out, try our fix in the interactive window -- it crashes when setting workspacetest 6: try same thing -- it crashestest 7 : try with capital T, -- it crashestest 8: run script with running man -- it crashestest 9: run script with step over -- it crashestest 10: add line of code setting workspace back into script. Run it -- it crashes. (though the vid stops just before this)I know there are alternatives to Pythonwin. But I'd really rather solve this problem then march off to a different editor. I know this stuff can be run at the Python command prompt inside Arc, but that doesn't have the debugging facilities of PythonWin. IDLE also doesn't have the nice debugging interface of PythonWin.Thanks!Here's the code I used in the video. (Though there's nothing wrong with the code itself.) If anyone would be kind enough to try this out, you can replace the line of code that points to my shapefile with one of your own, and it should work with no arguments. (input = "C:\\Temp\\COVER63p.shp" )
# exported2.py
# Created on: 2012-01-10 12:52:28.00000
# (generated by ArcGIS/ModelBuilder)
# Usage: exported2 <distance> <input> <output>
# Description:
# Import arcpy module
import arcpy
arcpy.env.overwriteOutput = 1
arcpy.env.workspace = "C:/Temp"
# Script arguments
distance = arcpy.GetParameterAsText(0)
if distance == '#' or not distance:
distance = "5 Feet" # provide a default value if unspecified
input = arcpy.GetParameterAsText(1)
if input == '#' or not input:
input = "C:\\Temp\\COVER63p.shp" # provide a default value if unspecified
output = arcpy.GetParameterAsText(2)
if output == '#' or not output:
output = "C:\\Temp\\abc.shp" # provide a default value if unspecified
# Process: Buffer
arcpy.Buffer_analysis(input, output, distance)
print arcpy.GetMessages()
