System ArcGIS 9.3Windows VistaHelloI want to run a arcscript (as attached) to do batch work.However, the error always showed that environment or tool not found. (gp.SplitByAttribute(inputFC, fieldName, outputWS, filePrefix) AttributeError: Object: Tool or environment not found)Please kindly help check if the following code is correct.If so, please kindly advise if it is possible to have missing link between the toolbox and tool.PS shapefile is also attached in test1.Thank you. ##Script Name: split rows
##Description: using
##Created By: Elaine Kuo
##Date: 23/09/2012
#Import standard library modules
import arcgisscripting
import os
#Create the Geoprocessor object
gp = arcgisscripting.create(9.3)
#Set the workspace.
gp.Workspace= "H:/temp/test1"
#Set the workspace. List all of the feature classes in the dataset
outWorkspace= "H:/temp/test1"
inputFC = "H:/temp/test1/geor0247_Dissolve.shp"
fieldName = "C0247"
outputWS = "H:/temp/test1"
filePrefix = "geor0427"
# Add a toolbox with a model to the geoprocessor and set the workspace
gp.AddToolbox("C:/TEMP/AdditionalAnalysis/Additional Analysis - Generic Tools.tbx")
#### Execute Script Tool ###
gp.AddMessage(gp.GetMessages())
print gp.GetMessages()
