I have some pop up logic written in for the Javascript API but I want to port that over to AGOL/Portal Web Map popups but my content logic revolves around the use of multi-dimensional arrays. I don't see anything explicitly stated in the documentation hence this post.
The context for this is that I have a census data layer which has 150 attribute fields with count values. For each non-zero value, it is added to a multi-dimensional array where the 1st column is a label, the second is the percentage based on a total population subset, and the third column in the array is the percentage based on the entire population of the census tract.
Once the array is fully populated, I sort the array in descending value order based on the 2nd column of the array and then build out an HTML table for the pop up. Anyways, I can do this in the JS API because it's pure JS but I'm not sure about Arcade.
Thanks!
