Hi
I was try to use convert arcpy.conversion.ExportFeatures to VB:NET
when I run the code nothing happened I see the Progress dialog then I don't get the shapefile
count1 = int(arcpy.GetCount_management("LAYERNAME").getOutput(0))
if count1 > 0:
#print('Layer has a selection')
arcpy.conversion.ExportFeatures(
in_features="LAYERNAME",
out_features=r"C:\PATH\file.shp",
where_clause="TYPE = 80",
use_field_alias_as_name="NOT_USE_ALIAS",
sort_field=None
else:
print('Layer has no selection')
Try
Dim currentLayer = GetBasicFeaturLayer(layerpath)
If currentLayer.ConnectionStatus = ConnectionStatus.Broken Then
End If
If currentLayer.SelectionCount = 0 Then
Else
Dim in_features = "LAYERNAME"
Dim out_features = "C:\PATH\file.shp"
Dim where_clause = "TYPE = 80"
Dim use_field_alias_as_name = "NOT_USE_ALIAS"
Dim sort_field = "None"
Dim progDlg = New ProgressDialog("Export map" & vbCrLf & "Go get a coffee", "Cancel")
progDlg.Show()
Dim progsrc=New CancelableProgressorSource(progDlg)
If Not System.IO.Directory.Exists(outpath) Then System.IO.Directory.CreateDirectory(outpath)
Dim valueArray = Await QueuedTask.Run(Function()
Dim inlayers As List(Of String) = New List(Of String)()
inlayers.Add(layerpath)
Return Geoprocessing.MakeValueArray(inlayers, outpath, where_clause, use_field_alias_as_name, sort_field)
End Function)
Dim flags As GPExecuteToolFlags = GPExecuteToolFlags.GPThread
Dim gpResult As IGPResult = Await Geoprocessing.ExecuteToolAsync("conversion.ExportFeatures", valueArray, Nothing, progsrc.CancellationTokenSource.Token, Nothing, flags)
progDlg.Hide()
Return If(String.IsNullOrEmpty(gpResult.ReturnValue), $"Error in gp tool: {gpResult.ErrorMessages}", $"Ok: {gpResult.ReturnValue}")
End If
Catch ex As Exception
MessageBox.Show(ex.Message)
End Try
