This is driving me crazy. I used a different Python script developed in Arcmap as a framework for this new script for use in ArcGIS Pro. The script is pretty basic- the user specifies two polygon layers and the script loops through all features in the first layer (theUnits in the script) and then does an overlap select against features in the second layer (theParcels). It then builts a unique list for values for a specific field and then populates a field in the first layer with that list of values.
The script runs through to completion but the attribute field it's supposed to populate remains empty. What am I overlooking? I've been running the script through a Toolbox Script tool and choosing the two layers which are present in my map.
FWIW, here's the tail end of the output pushed to the details window:
...Parcel FID List: 1502; 12075
2 parcels intersected and Trusts Encountered were: 2,42
Current ObjectID: 17482
Parcel FID List: 4656
1 parcels intersected and Trusts Encountered were: 1
Current ObjectID: 17483
Parcel FID List: 12100
Current ObjectID: 17484
Parcel FID List: 10375
Current ObjectID: 17485
Parcel FID List: 3101; 5204; 7300
3 parcels intersected and Trusts Encountered were: 1
Current ObjectID: 17490
Parcel FID List: 6957; 16736
2 parcels intersected and Trusts Encountered were: 3
Current ObjectID: 17491
Parcel FID List: 745; 3102; 4127; 5613
4 parcels intersected and Trusts Encountered were: 1
Current ObjectID: 17494
Parcel FID List: 97
1 parcels intersected and Trusts Encountered were: 3
Current ObjectID: 17495
Parcel FID List: 358
Current ObjectID: 17496
Parcel FID List: 97
Current ObjectID: 17500
Parcel FID List: 1011
SCRIPT SUCCESSFULLY PROCESSED 3948 SALE UNITS IN 0:19:04.009152
Here's the actual script:
# Import python modules
import arcpy, os, time
from datetime import timedelta
startTime = time.time()
# Link to and establish the required layers specified in the Toolbox dialog
theUnits = arcpy.GetParameterAsText(0)
theParcels = arcpy.GetParameterAsText(1)
arcpy.AddMessage('Timber Sale Units: ' + theUnits)
arcpy.AddMessage('Parcels: ' + theParcels)
workspace = 'G:/gis/PlannedSales\/20230907/20230907_pdr_7971.gdb'
# Start an edit session. Must provide the workspace.
edit = arcpy.da.Editor(workspace)
edit.startEditing(with_undo=False, multiuser_mode=True)
# Start an edit operation
edit.startOperation()
# Now let's loop through all of the Timber Sale Units.....
theCounter = 0
totalRecordCount = arcpy.GetCount_management(theUnits)
fields = ['OBJECTID', 'tTrusts', 'SHAPE@']
with arcpy.da.UpdateCursor(theUnits,fields) as theCursor:
for row in theCursor:
# Step 1: Unselect all applicable overlay themes & reset any variables ----
arcpy.SelectLayerByAttribute_management(theUnits, "CLEAR_SELECTION")
curTrustList = []
theCounter = theCounter + 1
# STEP 2: Get the current sale unit shape ---------------------------------
if (theCounter % 100 == 0):
curTime = time.time()
totalTime = curTime - startTime
totalTimeFormatted = "{:0>8}".format(str(timedelta(seconds=totalTime)))
arcpy.AddMessage("{0} of {1} records processed (elapsed time: {2})..".format(theCounter,totalRecordCount,totalTimeFormatted) )
curObjectID = row[0] #OBJECTID
arcpy.AddMessage('Current ObjectID: ' + str(curObjectID))
# STEP 4: Perform an overlap select against the Stands Polygons -----------
SelPoly = arcpy.SelectLayerByAttribute_management(theUnits, "NEW_SELECTION", "\"OBJECTID\" =" + str(curObjectID))
SelectedFeatures = arcpy.SelectLayerByLocation_management(theParcels, "INTERSECT", SelPoly)
matchcount = int(arcpy.GetCount_management(SelectedFeatures)[0])
desc = arcpy.Describe(SelectedFeatures)
arcpy.AddMessage('Parcel FID List: ' + desc.FIDSet)
trustFields = ['TIMBER_TRUST_CD', 'SHAPE@']
with arcpy.da.SearchCursor(SelectedFeatures,trustFields) as parcelCursor:
parcelCounter = 0
curList = []
for parcelRow in parcelCursor:
parcelCounter = parcelCounter + 1
curList.append(parcelRow[0])
curUniqueList = list(set(curList))
theTrustList = ",".join(str(element) for element in curUniqueList)
arcpy.AddMessage(str(matchcount) + ' parcels intersected and Trusts Encountered were: ' + theTrustList)
row[1] = theTrustList
theCursor.updateRow(row)
# Stop the edit operation.
#edit.stopOperation()
# Stop the edit session and save the changes
#edit.stopEditing(save_changes=True) # <== Throws error if uncommented: 'Cannot acquire a lock'
endTime = time.time()
totalTime = endTime - startTime
arcpy.AddMessage("\n\nSCRIPT SUCCESSFULLY PROCESSED {0} SALE UNITS IN {1}\n\n".format(totalRecordCount, totalTimeFormatted) )
