Hi. Our enterprise is using build 1500 of ArcGIS Explorer and this morning we've started to experience serious problems. Symptoms include:
ArcGIS Explorer opens but the basemap won’t redraw as we pan around. It just shows “Streaming…” at the bottom of the map for a while and then stops, but the basemap doesn’t fill in. Eventually, the application becomes unresponsive and must be closed through the windows task manager.
Other times panning works but then AGX hangs when we try to change the basemap.
After killing the application with the task manager, AGX may or, more likely, may not open again - either hanging at the splash screen or partially open.
It seems to revolve around the basemaps, but it's hard to tell since it hangs up pretty quickly.
Everything was working fine at the end of last week. The only thing I know that changed over the weekend is IE 10 was pushed out to our computers. Does anyone know if that would affect ArcGIS Explorer in this (or any) manner? Or have any thoughts in general?
Mary Ellen
