Hello!
So this question applies to Experience Builder running on Enterprise 11.2.
Just like the subject says: I am trying to embed an app and want to use URL parameters to filter the records based on two different values of the same attribute, and in the same data source.
So for example, I have dataSource1 and a column called 'test' with the values 'a' and 'b'.
If I wanted to use an URL to just show the records related to "test=a', the syntax would be:
<url>&data_filter=dataSource1:test='a'
Likewise, if I wanted to filter by b, it'd be:
<url>&data_filter=dataSource1:test='b'
But what if I wanted to filter by both 'a' and 'b'? Everything I've tried so far excludes one of the parameters, and the documentation about passing multiple filters assumes multiple data sources and columns instead of from the same one. Is this just not possible in Experience Builder the way it is with Dashboards (ie. in Dashboards, the Category type URL parameter can do this = '#param=a,b')?
