Hello ... Just beginning to learn ArcGIS Pro 3.2. I was digitizing a number of objects from a raster image for the purpose of image classification to be used to create a deep learning training set. One of the labeled objects is a mistake. I found the problem object in the labeled objects list (it highlights on the map after clicking it) and double-clicked it to zoom to it on the map. But, when trying to delete it with the red "X" on the Label Objects menu, which is greyed out, it says no object is selected. But the object on the map is clearly selected and shows in a different color. I have gone through the HELP pages and believe I did what I was supposed to, but it did not remove the object.
How can I delete this errored labeled object entry?
Thank you.
