Hello all,
I'm playing around with the web app templates that are offered on ArcGIS Online. What I'm trying to do is populate the map in the web app using a WMS service on my ArcGIS Server. The issue I'm having is that the web app is looking for some form of "Map ID" that is usually found when you publish a map on ArcGIS Online or Portal for ArcGIS. Is there an option to have the map just be based on the layers within the WMS?
Here's a few code lines from the default.js:
//default web map, default app color theme and more. These values can be overwritten by template configuration settings and url parameters.
"appid": "",
"webmap": "",
//Defaults to arcgis.com. Set this value to your portal or organization host name.
"sharinghost": location.protocol + "//" + "",
I've tried setting the "sharinghost" to something like "myserver/arcgis/services/service/mapserver" in all kinds of variations, but just returns an error on the webpage:
Unable to create map: Unable to load http://myserver/arcgis/services/service/mapserver/sharing/rest/portals/self?f=json status: 403
Anyone know if what I'm trying to do is even possible? And if so, how I might go about bypassing Online/Portal?
My thanks,
Todd
