Greetings!
I have always had a problem w/basemap resolution when exporting maps. I figured out how to change all of my export settings so that the maps look great when I export - but then the file size is so large that recipients complain that they can't open or work with the files and ask me to reduce them. And then, of course, when I reduce the file size, the maps look terrible again.
It's generally the basemap and labels on the basemap that are the problem - but they look so bad that it's completely unacceptable. The only solution seems to be that I need to go and just create all of my own basemaps again, build out streets, city names, etc., etc., and that can be an awful lot of work for what should be an otherwise simple project. Sometimes there are still weird labels or items that I can't get rid of, even when I turn the reference layer off.
What do you all do about this? Do you just create your own basemaps of roads, feature labels, etc.? It's just maddening that there are these beautiful basemaps and I can't make use of them.
(Though, separate issue that I need to figure out: there are lots of basemaps I used do use in ArcMap that were easily accessible within Map that I can't find or import into Pro anymore using Catalog and that makes me super sad as well. I'm sure there's another whole far more complicated process I need to figure out to access those - if it's still possible.)
Thank you!!
