I'm calling this code from a button on a dockpane. The current attribute value is null and I am changing the value to a number, so there should be a change, but the modifyFeature Edit Operation is empty after the Modify. Any ideas on what might be causing this?
public static void SetFieldInt(Map? map, string layerName, string fieldName, int value)
try
if (map is null) return;
BasicFeatureLayer? featureLayer = (BasicFeatureLayer?)FindLayer(map, layerName);
if (featureLayer is null)
return;
else
Selection selectedFeatures = featureLayer.GetSelection();
var modifyInspector = new Inspector();
using (RowCursor rowCursor = selectedFeatures.Search())
while (rowCursor.MoveNext())
if (rowCursor.Current is not Feature feature) return;
long oid = feature.GetObjectID();
if (feature != null)
object den = feature[2];
modifyInspector.Load(featureLayer, feature.GetObjectID());
var modifyFeature = new EditOperation
Name = "Modify a feature"
modifyInspector[fieldName] = value;
modifyFeature.Modify(modifyInspector);
if (!modifyFeature.IsEmpty)
var result = modifyFeature.Execute();
catch (Exception ex)
throw new SystemException((System.Reflection.MethodBase.GetCurrentMethod()!.Name ?? "Unknown") + ": " + ex.Message);
Thanks!
- David Wilcox
