I am having issues with the elevation void fill function in arcgis pro.
Im trying to make a map of the groundwater level of a municipalety in the Netherlands. After the elevation void fill function creates a new layer arcgis slows down significantly, with my cpu usage (intel i7-8565U) staying between 50 and 100%. Otherwise it seems fine untill i try to use or alter the layer. After about 5 to 20 minutes the red exclamation mark will appear and the layer source is nowhere to be found. I will be able to, for example, edit te symbology for a while, untill I can't, then the layer goes blank and the red exclamation mark appears.
I ran the tool again and could not find the source even when the layer was still responding normally.
Does anyone know how to fix it or why it is happening?
