How are the KPH. and Minutes fields calculated when you create a network data set? I have a network data set that I've built and I needed to update some intersections. I made my edits and am now trying to figure out how to calculate the KPH and Minutes fields so that when a route uses the newly added road segments, the time calculation is correct. OR is the Miles and Minutes all that are needed? If so, how are the minutes calculated? #CostAnalysis #NetworkAnalyst #NetworkDataset #CostAttribute #Miles #Minutes #KPH
