Is there a way to check if a field is blank or null and if it's not continue the script? I can't quite get the function to work unless I'm missing something. Thanks
<SPAN class="" style="color: #0077aa; border: 0px; font-weight: inherit; font-size: 14px;">if</SPAN> row<SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">[</SPAN><SPAN class="" style="color: #990000; border: 0px; font-weight: inherit; font-size: 14px;">0</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">]</SPAN> <SPAN class="" style="color: #a67f59; background: rgba(255, 255, 255, 0.5); border: 0px; font-weight: inherit; font-size: 14px;">!=</SPAN> <SPAN class="" style="color: #669900; border: 0px; font-weight: inherit; font-size: 14px;">""</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">:</SPAN> <SPAN class="" style="color: slategray; border: 0px; font-weight: inherit; font-size: 14px;"># if field is not blank or null then...</SPAN>
<SPAN class="keyword token">import</SPAN> sys
<SPAN class="keyword token">import</SPAN> os
<SPAN class="keyword token">import</SPAN> arcpy
sdeconnection <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Database Connections/SDE.sde"</SPAN>
fc <SPAN class="operator token">=</SPAN> <SPAN class="string token">'Database Connections/SDE.sde/NEO.SDE.Inspections/NEO.SDE.ACInspectionSites2019'</SPAN>
fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"INSPECTEDBY"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"INSPECTIONSTATUS"</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN>
edit <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>Editor<SPAN class="punctuation token">(</SPAN>sdeconnection<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"edit created"</SPAN>
edit<SPAN class="punctuation token">.</SPAN>startEditing<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"edit started"</SPAN>
edit<SPAN class="punctuation token">.</SPAN>startOperation<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"operation started"</SPAN>
<SPAN class="comment token"># Perform edits</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN> fields<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token"># For each row, evaluate the WELL_YIELD value (index position </SPAN>
<SPAN class="comment token"># of 0), and update WELL_CLASS (index position of 1)</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">!=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># if field is not blank or null then...</SPAN>
row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Completed Inspection"</SPAN>
<SPAN class="comment token"># Update the cursor with the updated list</SPAN>
cursor<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN>
edit<SPAN class="punctuation token">.</SPAN>stopOperation<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"operation stopped"</SPAN>
edit<SPAN class="punctuation token">.</SPAN>stopEditing<SPAN class="punctuation token">(</SPAN><SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">## Stop the edit session with True to save the changes </SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"edit stopped"</SPAN>
<SPAN class="keyword token">except</SPAN> Exception <SPAN class="keyword token">as</SPAN> err<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> err
<SPAN class="keyword token">if</SPAN> <SPAN class="string token">'edit'</SPAN> <SPAN class="keyword token">in</SPAN> locals<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> edit<SPAN class="punctuation token">.</SPAN>isEditing<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"operation stopped in except"</SPAN>
edit<SPAN class="punctuation token">.</SPAN>stopEditing<SPAN class="punctuation token">(</SPAN><SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">## Stop the edit session with False to abandon the changes </SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"edit stopped in except"</SPAN>
<SPAN class="keyword token">finally</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token"># Cleanup </SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>ClearWorkspaceCache_management<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
