I've been trying to resolve this issue, but I can't find a real answer.
Most of the Clip-Zip-Ship scripts I found are for earlier versions or links broken.
The rest of the codes I tried, but I'm missing something.
I'm making a custom widget based on Sketch widget within ExB / JS API to use GP submitJob for async GPService. After drawing a polygon on map, the event complete fires and should send the params to the GPService.
My problem is with the Area_Of_Interest parameter.
I don't know the format it expects. I tried so many and each one just throws an error.
One of them worked without errors, copied all the tables schema but no data. Its like I didn't send params.
GP Service Link
clip_zip_ship
If I use the SubmitJob through the service, it works even with minimal params. But if I take the code inside JS it's not working or gives me empty result. My guess is I'm formatting the JSON incorrectly through JS.
Here is my main file where I'm trying out the scripts.
<html lang="en">
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>
Watch for changes | Sample | ArcGIS Maps SDK for JavaScript 4.27
</title>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.27/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.27/"></script>
<script type="module" src="https://js.arcgis.com/calcite-components/1.8.0/calcite.esm.js"></script>
<link rel="stylesheet" type="text/css" href="https://js.arcgis.com/calcite-components/1.8.0/calcite.css" />
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
overflow: hidden;
</style>
<script>
require([
"esri/views/MapView",
"esri/WebMap",
"esri/widgets/Sketch",
"esri/layers/GraphicsLayer",
"esri/rest/geoprocessor",
"esri/rest/support/JobInfo",
"esri/geometry/Polygon"
], (MapView, WebMap, Sketch, GraphicsLayer, geoprocessor, JobInfo, Polygon) => {
// Load a webmap from ArcGIS Online
const webmap = new WebMap({
portalItem: {
// autocasts as new PortalItem()
let graphicsLayer = new GraphicsLayer({
effect: "brightness(3) hue-rotate(120deg) contrast(100%)"
// Create a view and set view's map to the webmap
const view = new MapView({
container: "viewDiv",
map: webmap,
padding: {
right: 350
view.when(() => {
webmap.add(graphicsLayer);
// create a new sketch widget
const sketch = new Sketch({
view,
layer: graphicsLayer,
sketch.visibleElements = {
createTools: {
circle: false,
rectangle: false,
point: false,
polyline: false,
polygon: true
selectionTools:{
"lasso-selection": false,
"rectangle-selection": true
settingsMenu: false,
undoRedoMenu: false,
duplicateButton: false
view.ui.add(sketch, "top-right");
sketch.on("create", function(event) {
// check if the create event's state has changed to complete indicating
// the graphic create operation is completed.
if (event.state === "complete") {
// remove the graphic from the layer. Sketch adds
// the completed graphic to the layer by default.
// polygonGraphicsLayer.remove(event.graphic);
const geometryArrays = [];
const geometry_extent_Arrays = event.graphic.geometry.rings[0];
const geometry_simp = event.graphic.geometry.toJSON();
const geometry_extent_Arrays_length = geometry_extent_Arrays.length;
const json_geometry = JSON.stringify(geometry_extent_Arrays);
const json_extent_map = view.extent.extent.toJSON();
let arau_rings = "";
// const area = Polygon.fromExtent(view.extent);
// use the graphic.geometry to query features that intersect it
// selectFeatures(event.graphic.geometry);
console.log(view.extent.toJSON());
for(shlj = 0; shlj < geometry_extent_Arrays_length; shlj++){
let ring_x = geometry_extent_Arrays[shlj][0];
let ring_y = geometry_extent_Arrays[shlj][1];
arau_rings += "["+ring_x+", "+ring_y+"]";
if(shlj == geometry_extent_Arrays_length-1){arau_rings += "";}else{arau_rings += ",";}
const polytest = new Polygon({
hasZ: false,
hasM: false,
rings: geometry_extent_Arrays,
spatialReference: { wkid: 4326 }
console.log(json_extent_map);
const clipped_layers = ["mepso_dev.sde.power_substation","mepso_dev.sde.pole","mepso_dev.sde.overhead_transmission_line","mepso_dev.sde.optical_cable"];
const area_of_interest3 = {
"paramName": "Area_of_Interest",
"dataType": "GPFeatureRecordSetLayer",
"value": {
"displayFieldName": "",
"geometryType": "esriGeometryPolygon",
"spatialReference": {"wkid": 4326},
"fields": [
"name": "FID",
"type": "esriFieldTypeOID",
"alias": "FID"
"name": "Id",
"type": "esriFieldTypeInteger",
"alias": "Id"
"name": "Shape_Length",
"type": "esriFieldTypeDouble",
"alias": "Shape_Length"
"name": "Shape_Area",
"alias": "Shape_Area"
"features": [],
"exceededTransferLimit": false
const area_of_interest2 = {"geometryType":"esriGeometryPolygon","features":[{"geometry":{"rings":[[[2379510.7538454947,5164667.770819161],[2379510.7538454947,5175674.702892231],[2394339.537332825,5175674.702892231],[2394339.537332825,5164667.770819161],[2379510.7538454947,5164667.770819161]]],"spatialReference":{"wkid":102100}}}],"sr":{"wkid":102100}};
const area_of_interest = {
"spatialReference": {"wkid": null},
"fields": [
"name": "FID",
"alias": "FID"
"name": "Id",
"alias": "Id"
"features": [geometry_simp],
const area_of_interest4 = {
"GET": {
"scheme": "https",
"host": "address.katastar.gov.mk",
"filename": "/arcgis/rest/services/AddressRegister2018_WEB/ClipZipShip_2019/GPServer/Extract%20Data%20Task/submitJob",
"query": {
"f": "json",
"env:outSR": "6316",
"Layers_to_Clip": "[\"Куќни броеви\",\"Улици\",\"Објекти\",\"Парцели\",\"Населени места\"]",
"Area_of_Interest": "{\"geometryType\":\"esriGeometryPolygon\",\"features\":[{\"geometry\":{\"rings\":[[[7538744.821275976,4647957.64967497],[7539743.88994078,4648533.384159772],[7542487.095427191,4647110.9813149655],[7541860.560840788,4645739.37857176],[7540302.691058381,4644452.442664555],[7538575.487603975,4644638.709703756],[7538304.553728774,4646416.713259763],[7538744.821275976,4647957.64967497]]],\"spatialReference\":{\"wkid\":6316}}}],\"sr\":{\"wkid\":6316}}",
"Feature_Format": "Shapefile - SHP - .shp"
"remote": {
"Address": "185.177.12.221:443"
"{\"geometryType\":\"esriGeometryPolygon\",\"features\":[{\"geometry\":{\"rings\":[[[7538744.821275976,4647957.64967497],[7539743.88994078,4648533.384159772],[7542487.095427191,4647110.9813149655],[7541860.560840788,4645739.37857176],[7540302.691058381,4644452.442664555],[7538575.487603975,4644638.709703756],[7538304.553728774,4646416.713259763],[7538744.821275976,4647957.64967497]]],\"spatialReference\":{\"wkid\":6316}}}],\"sr\":{\"wkid\":6316}}";
const feature_format = "Shapefile - SHP - .shp";
const output_zip = "mepso_dev_ClipZipShip";
const gpUrl =
"https://app.gdi.mk/arcgis/rest/services/MEPSO/clip_zip_ship_za_test_david/GPServer/clip_zip_ship";
const options = {
const reqOptions = {
const params = {
Layers_To_Clip: clipped_layers,
Area_Of_Interest: area_of_interest4,
Feature_Format: feature_format,
Output_Zip_File: output_zip
const params2 = {
// const reqParams = {
// messages: <GPMessage[]>,
// results: <ParameterValue[]>
geoprocessor.submitJob(gpUrl, params, options, reqOptions).then((jobInfo) => {
const jobid = jobInfo.jobId;
// console.log("Area of Interest: ", geometry_extent_Arrays);
console.log("ArcGIS Server job ID: ", jobid);
const newoptions = {
interval: 1500,
statusCallback: (j) => {
console.log("Job Status: ", j.jobStatus);
jobInfo.waitForJobCompletion(newoptions).then(() => {
const result = jobInfo.fetchResultData();
document.getElementById('czs').innerText = JSON.stringify(result);
console.log(result);
// displayMessage(info);
// displayMessage(send_string);
var btn = document.createElement('button');
btn.innerText = 'Clip';
btn.className = "esri-widget esri-widget--button esri-widget esri-interactive";
view.ui.add(btn, 'bottom-left');
btn.addEventListener('click', () => {
view.ui.remove(sketch);
function hide_sketch(){
const sketch_div = document.getElementsByClassName("esri-ui-top-right esri-ui-corner");
sketch_div[0].hidden = "true";
</script>
</head>
<body>
<div id="viewDiv"><div id="czs"></div>
<!-- <calcite-action-pad>
<calcite-action text="Add" icon="plus" id="gp_request"></calcite-action>
<calcite-action text="Save" icon="save" onclick="hide_sketch()"></calcite-action>
<calcite-action text="Layers" icon="layers"></calcite-action>
<calcite-action text="Basemaps" icon="layer-basemap"></calcite-action>
<calcite-tooltip slot="expand-tooltip">Toggle Action Bar</calcite-tooltip>
</calcite-action-pad> -->
</div>
</body>
</html>
I also uploaded a zip with the files. What am I missing?
