HI Community. I want to implement location display in Sketch On Map application. Below is my code
/* Copyright 2023 Esri
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
package com.esri.arcgismaps.sample.sketchonmap
import android.os.Bundle
import android.util.Log
import android.view.View
import android.widget.AdapterView
import android.widget.ArrayAdapter
import androidx.appcompat.app.AppCompatActivity
import androidx.databinding.DataBindingUtil
import androidx.lifecycle.lifecycleScope
import com.arcgismaps.ApiKey
import com.arcgismaps.ArcGISEnvironment
import com.arcgismaps.Color
import com.arcgismaps.geometry.GeometryBuilder
import com.arcgismaps.geometry.GeometryType
import com.arcgismaps.geometry.Multipoint
import com.arcgismaps.geometry.Point
import com.arcgismaps.geometry.Polygon
import com.arcgismaps.geometry.Polyline
import com.arcgismaps.mapping.ArcGISMap
import com.arcgismaps.mapping.BasemapStyle
import com.arcgismaps.mapping.Viewpoint
import com.arcgismaps.mapping.symbology.SimpleFillSymbol
import com.arcgismaps.mapping.symbology.SimpleFillSymbolStyle
import com.arcgismaps.mapping.symbology.SimpleLineSymbol
import com.arcgismaps.mapping.symbology.SimpleLineSymbolStyle
import com.arcgismaps.mapping.symbology.SimpleMarkerSymbol
import com.arcgismaps.mapping.symbology.SimpleMarkerSymbolStyle
import com.arcgismaps.mapping.view.Graphic
import com.arcgismaps.mapping.view.GraphicsOverlay
import com.arcgismaps.mapping.view.MapView
import com.arcgismaps.mapping.view.geometryeditor.FreehandTool
import com.arcgismaps.mapping.view.geometryeditor.GeometryEditor
import com.arcgismaps.mapping.view.geometryeditor.VertexTool
import com.esri.arcgismaps.sample.sketchonmap.databinding.ActivityMainBinding
import com.google.android.material.snackbar.Snackbar
import kotlinx.coroutines.launch
import android.Manifest.permission.ACCESS_COARSE_LOCATION
import android.Manifest.permission.ACCESS_FINE_LOCATION
import com.arcgismaps.location.LocationDisplayAutoPanMode
class MainActivity : AppCompatActivity() {
private val activityMainBinding: ActivityMainBinding by lazy {
DataBindingUtil.setContentView(this, R.layout.activity_main)
private val mapView by lazy {
activityMainBinding.mapView
private val selectedGeometryDropdown by lazy {
activityMainBinding.pointLinePolygonToolbar.selectGeometryDropdown
// create a symbol for the point graphic
private val pointSymbol: SimpleMarkerSymbol by lazy {
SimpleMarkerSymbol(SimpleMarkerSymbolStyle.Square,
Color(getColor(R.color.point_symbol_color)),
20f)
// create a symbol for a line graphic
private val lineSymbol: SimpleLineSymbol by lazy {
SimpleLineSymbol(
SimpleLineSymbolStyle.Solid,
Color(getColor(R.color.line_symbol_color)),
4f
// create a symbol for the fill graphic
private val fillSymbol: SimpleFillSymbol by lazy {
SimpleFillSymbol(
SimpleFillSymbolStyle.Cross,
Color(getColor(R.color.fill_symbol_color)),
lineSymbol
// keep the instance graphic overlay to add graphics on the map
private var graphicsOverlay: GraphicsOverlay = GraphicsOverlay()
// keep the instance of the freehand tool
private val freehandTool: FreehandTool = FreehandTool()
// keep the instance of the vertex tool
private val vertexTool: VertexTool = VertexTool()
// keep the instance to create new geometries, and change existing geometries
private var geometryEditor: GeometryEditor = GeometryEditor()
override fun onCreate(savedInstanceState: Bundle?) {
super.onCreate(savedInstanceState)
// authentication with an API key or named user is
// required to access basemaps and other location services
ArcGISEnvironment.apiKey = ApiKey.create(BuildConfig.API_KEY)
lifecycle.addObserver(mapView)
// create and add a map with a navigation night basemap style
mapView.apply {
map = ArcGISMap(BasemapStyle.ArcGISImagery)
ArcGISEnvironment.applicationContext = applicationContext
locationDisplay.setAutoPanMode(LocationDisplayAutoPanMode.Recenter)
setViewpoint(Viewpoint(10.656295, 76.195800, 3500000.0))
graphicsOverlays.add(graphicsOverlay)
// set MapView's geometry editor to sketch on map
mapView.geometryEditor = geometryEditor
// enable/disable the undo button if last event can be undone
lifecycleScope.launch {
geometryEditor.canUndo.collect { value ->
activityMainBinding.pointLinePolygonToolbar.undoButton.isEnabled = value
// enable/disable the redo button if the last event can be redone
geometryEditor.canRedo.collect { value ->
activityMainBinding.pointLinePolygonToolbar.redoButton.isEnabled = value
// set up the geometry list dropdown
selectedGeometryDropdown.apply {
// set the adapter to the list of geometries
setAdapter(
ArrayAdapter(
applicationContext,
com.esri.arcgismaps.sample.sampleslib.R.layout.custom_dropdown_item,
resources.getStringArray(R.array.geometry_list)
// set the dropdown click listener
onItemClickListener = AdapterView.OnItemClickListener { _, _, position, _ ->
// set the GeometryEditorTool and then start the editing process
geometryEditor.apply {
when (position) {
0 -> {
tool = freehandTool
start(GeometryType.Polygon)
1 -> {
tool = freehandTool
start(GeometryType.Polyline)
2 -> {
tool = vertexTool
start(GeometryType.Multipoint)
3 -> {
tool = vertexTool
start(GeometryType.Point)
4 -> {
tool = vertexTool
5 -> {
tool = vertexTool
* Undo the last event on the GeometryEditor.
fun undo(view : View) {
geometryEditor.undo()
* Redo the last undone event on the GeometryEditor.
fun redo(view : View) {
geometryEditor.redo()
* When the stop button is clicked, check that sketch is valid. If so, get the geometry from
* the sketch, set its symbol and add it to the graphics overlay.
fun stop(view : View) {
// get the geometry from sketch editor
val sketchGeometry = geometryEditor.geometry.value
?: return showMessage("Error retrieving geometry")
if (!GeometryBuilder.builder(sketchGeometry).isSketchValid) {
return reportNotValid()
// stops the editing session
geometryEditor.stop()
// clear the UI selection
selectedGeometryDropdown.setText("")
selectedGeometryDropdown.clearFocus()
// create a graphic from the sketch editor geometry
val graphic = Graphic(sketchGeometry).apply {
// assign a symbol based on geometry type
symbol = when (sketchGeometry) {
is Polygon -> fillSymbol
is Polyline -> lineSymbol
is Point, is Multipoint -> pointSymbol
else -> null
// add the graphic to the graphics overlay
graphicsOverlay.graphics.add(graphic)
* Clear the MapView of all the graphics and reset selections
fun clear(view : View) {
geometryEditor.clearGeometry()
geometryEditor.clearSelection()
showMessage(getString(R.string.cleared_message))
* Clear all editing and applied graphics on the map
fun restart(view : View) {
graphicsOverlay.graphics.clear()
showMessage(getString(R.string.restart_message))
* Called if sketch is invalid. Reports to user why the sketch was invalid.
private fun reportNotValid() {
// get the geometry currently being added to map
val geometry = geometryEditor.geometry.value ?: return showMessage("Geometry not found")
// find the geometry type, and set the valid message
val validIfText: String = when (geometry) {
is Point -> getString(R.string.invalid_point_message)
is Multipoint -> getString(R.string.invalid_multipoint_message)
is Polyline -> getString(R.string.invalid_polyline_message)
is Polygon -> getString(R.string.invalid_polygon_message)
else -> getString(R.string.none_selected_message)
// set the invalid message to the TextView.
showMessage(validIfText)
private fun showMessage(message: String) {
Log.e(localClassName, message)
Snackbar.make(mapView, message, Snackbar.LENGTH_SHORT).show()
Can anyone suggest what additional steps/code i have to add. I had already modified the AndroidManifest .XML to include COARSE LOCATION and FINE LOCATION.
