Hi everyone,
I'm currently having the problem, that when I initialize a map with multiple tokens for multiple services on one server, the default login dialogs for the services appearing.
If I initialize the map with only one service from the server everything works fine.
The strangest behavior is that, when I close the login dialogs, the services are working fine with there tokens.
Using one server account to secure both services is no option for me.
So my question is, does anybody know this problem or had a similar problem?
The following code represents the object wich I'm using to initialize the IdentityManager. (only the real server adress is changed to "[server]")
result <SPAN class="operator token">=</SPAN> Object
credentials <SPAN class="operator token">=</SPAN> Array<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="number token">0</SPAN> <SPAN class="operator token">=</SPAN> Object
creationTime <SPAN class="operator token">=</SPAN> <SPAN class="string token">"1496311425650"</SPAN>
expires <SPAN class="operator token">=</SPAN> <SPAN class="string token">"1496315025650"</SPAN>
resources <SPAN class="operator token">=</SPAN> Array<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="number token">0</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2F%5Bserver%5D.de%2Farcgis%2Frest%2Fservices%2FMAO%2Fmao_demo_2017%2FMapServer" target="_blank">https://[server].de/arcgis/rest/services/MAO/mao_demo_2017/MapServer</A><SPAN>"</SPAN></SPAN>
length <SPAN class="operator token">=</SPAN> <SPAN class="number token">1</SPAN>
__proto__ <SPAN class="operator token">=</SPAN> Array<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
scope <SPAN class="operator token">=</SPAN> <SPAN class="string token">"server"</SPAN>
server <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2F%5Bserver%5D.de%2Farcgis" target="_blank">https://[server].de/arcgis</A><SPAN>"</SPAN></SPAN>
ssl <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN>
token <SPAN class="operator token">=</SPAN> <SPAN class="string token">"hsdN7wcE9InpFjH_NNZRSyYpOiOg1-AMWa_akcjCBxLFGuakYpDN9a__F0OB8Jb3owRmzzKulKLz85bmh-swIqUKDd4l5JInCGVvXFdlVgk."</SPAN>
userId <SPAN class="operator token">=</SPAN> <SPAN class="string token">"mao_user_Demo"</SPAN>
validity <SPAN class="operator token">=</SPAN> <SPAN class="string token">"7200"</SPAN>
__proto__ <SPAN class="operator token">=</SPAN> Object
<SPAN class="number token">1</SPAN> <SPAN class="operator token">=</SPAN> Object
creationTime <SPAN class="operator token">=</SPAN> <SPAN class="string token">"1496311425681"</SPAN>
expires <SPAN class="operator token">=</SPAN> <SPAN class="string token">"1496315025681"</SPAN>
<SPAN class="number token">0</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2F%5Bserver%5D.de%2Farcgis%2Frest%2Fservices%2FMAO%2Fmao_standard_2017%2FMapServer" target="_blank">https://[server].de/arcgis/rest/services/MAO/mao_standard_2017/MapServer</A><SPAN>"</SPAN></SPAN>
token <SPAN class="operator token">=</SPAN> <SPAN class="string token">"dlFkKxoSucnU5Oc4RKopeo5LXWGvO4JiGMec4l6XD9ym7iMzoX6YeWfrh75BnP90V_W6SGnm85M4E7BT6r8w8gZkyyG_0gL24JYm-WngbpQ."</SPAN>
userId <SPAN class="operator token">=</SPAN> <SPAN class="string token">"mao_user"</SPAN>
length <SPAN class="operator token">=</SPAN> <SPAN class="number token">2</SPAN>
oAuthInfos <SPAN class="operator token">=</SPAN> Array<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
serverInfos <SPAN class="operator token">=</SPAN> Array<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN>
adminTokenServiceUrl <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2F%5Bserver%5D.de%2Farcgis%2Fadmin%2FgenerateToken" target="_blank">https://[server].de/arcgis/admin/generateToken</A><SPAN>"</SPAN></SPAN>
currentVersion <SPAN class="operator token">=</SPAN> <SPAN class="number token">10.31</SPAN>
hasServer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN>
shortLivedTokenValidity <SPAN class="operator token">=</SPAN> <SPAN class="number token">60</SPAN>
tokenServiceUrl <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2F%5Bserver%5D.de%2Farcgis%2Ftokens%2F" target="_blank">https://[server].de/arcgis/tokens/</A><SPAN>"</SPAN></SPAN>
__proto__ <SPAN class="operator token">=</SPAN> Object<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
