As we migrate from ArcGIS Pro 2.x to ArcGIS Pro 3.x, we a looking at Python Code.
I note in Pro 2.x the syntax in the documentation code samples for say Clip Analysis in the code samples is
arcpy.Clip_analysis
Yet in pro 3.x it has switched to
arcpy.analysis.Clip
Can anyone advise when this changed?
Do both work in Pro 3.x?
With the new syntax, I note my PyCharm code intelligence is now stuffed as well. I think this is because the code document has not been changed. ie this is in the analysis.py file in ArcPy
# Extract toolset
@gptooldoc('Clip_analysis', None)
def Clip(in_features=None, clip_features=None, out_feature_class=None, cluster_tolerance=None):
"""Clip_analysis(in_features, clip_features, out_feature_class, {cluster_tolerance})
Cheers,
Mark
