We are working on implementing a new UG Electric Locate(s) Project. We also want to add our Electric Infrastructure (Hosted Feature Layer in AGOL from ArcGIS Pro) as a layer in the Project. From opening the Dispatcher and Field Worker Map in ArcGIS Online Map Viewer, I was able to add and configure the layer(s) and attributes. However, when opening the project in Workforce (Dispatcher & Field Worker Map), the user is not able to select a feature (Overhead Primary, Transformer, etc) and view the attributes behind the layer. Is there a setting I am missing? Need it to work the same way as Field Maps does (For viewing attachments, attributes, etc), without requiring our locator to open a completely separate map.
Thank You
