A client reported an error 'ORA-29861: domain index is marked LOADING/FAILED/UNUSABLE' while trying to load a raster.
Looking into the issue, we see that the Domain index on the SDE.DGB_ITEMS is the only invalid index.
We tried a rebuild of the index (as the SDE user) which failed with the following error:
alter index "SDE"."A1_IX1" rebuild
Error report -
ORA-29858: error occurred in the execution of ODCIINDEXALTER routine
ORA-20085: Parameter ST_SRID 0 is different from ST_GEOMETRY_COLUMNS srid (4326).
ORA-06512: at "SDE.SPX_UTIL", line 1245
ORA-06512: at "SDE.ST_DOMAIN_METHODS", line 1345
ORA-06512: at "SDE.ST_DOMAIN_METHODS", line 2492
29858. 00000 - "error occurred in the execution of ODCIINDEXALTER routine"
*Cause: Failed to successfully execute the ODCIIndexAlter routine.
*Action: Check to see if the routine has been coded correctly.
I'm not sure where it is getting the ST_SRID '0' from.
The index is defined as:
CREATE INDEX "SDE"."A1_IX1" ON "SDE"."GDB_ITEMS" ("SHAPE")
INDEXTYPE IS "SDE"."ST_SPATIAL_INDEX" PARAMETERS ('ST_GRIDS = 100 ST_SRID = 4326 ST_COMMIT_ROWS = 10000 PCTFREE 0 INITRANS 4');
All the st_geometries in the table are either null or have 4326 defined in them.
As we believe this is a system generated table we are not sure if dropping and recreating the index will break other things.
Note a second attempt at rebuilding the index provided a slightly different error:
ORA-20083: Parameter ST_SRID does not exist in ST_SPATIAL_REFERENCES table.
ORA-06512: at "SDE.SPX_UTIL", line 1232
Any suggestions?
Note:
Oracle 19c
This is the UV database, the loading of the rasters into development worked perfectly
Regards
Gunther
