HI
I am upgrading ArcGIS runtime 10.2.7 to ArcGIS Maps SDK for .NET 200.1.0 . in Xaml <esri:PictureMarkerSymbol /> is there. Any alternative we have use in 200.1.0 runtime
PictureMarkerSymbol can be created with either a Uri in the constructor or from a stream of bytes.
There's been a slight shift in the API and leaning more towards model objects (like your map definition) to be created in your models or viewmodels, rather than in XAML, and keeping the XAML bit focused on the UI pieces.
In the back end assigning image to this xaml tag of mapview resource. so need to get alternative of this
The above two links are how you can create picture marker symbols in v100.x+ . Moving from 10.x releases you're going to have to adapt to some various new patterns. While the feature set is the same (and then some), the way you achieve all the features might be slightly different.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und mehr. Neu hier? Registriere ein kostenloses Konto.
