I am trying to install Developer Edition 1.12 and the client install is failing with:
4426 verbose stack at ClientRequest.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\minipass-fetch\lib\index.js:130:14)
4426 verbose stack at ClientRequest.emit (node:events:513:28)
4426 verbose stack at TLSSocket.socketErrorListener (node:_http_client:502:9)
4426 verbose stack at TLSSocket.emit (node:events:525:35)
4426 verbose stack at emitErrorNT (node:internal/streams/destroy:151:8)
4426 verbose stack at emitErrorCloseNT (node:internal/streams/destroy:116:3)
4426 verbose stack at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
4427 verbose cwd C:\Program Files\ArcGIS\ArcGISExperienceBuilder\client
4428 verbose Windows_NT 10.0.17763
4429 verbose node v18.15.0
4430 verbose npm v9.5.0
4431 error code ENOTFOUND
4432 error syscall getaddrinfo
4433 error errno ENOTFOUND
4435 error network This is a problem related to network connectivity.
4435 error network In most cases you are behind a proxy or have bad network settings.
4435 error network
4435 error network If you are behind a proxy, please make sure that the
4435 error network 'proxy' config is set properly. See: 'npm help config'
Is there something I am doing wrong or is this a problem in the version?
