ArcGIS Pro installs a Python Command Prompt shortcut in startup which is handy. Launching it results in a command line that looks like this:
with the arcgispro-py3 environment and the directory shown. What is the best procedure for modifying the startup to default to a different directory, say...c:\temp for example instead of C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3? I peaked inside the batch (bat) files associated with the shortcut and saw nothing obvious to a person illiterate in batch language, and did not want to break anything, so could use some help.
Thank you,
Tyler
ArcGIS Pro 3.1.0
