After mainly installing the web-adaptor patch due to the bugs around the adaptor, stop responding to requests. We now have issues creating new hosted feature services. It also seems to be missing the feature-hosted services. (relational data)
The Datastore is up and running, and I can't find any errors in the logs.
The Validation of the relational data datastores is green.
The validation of operations in Portal is also green.
But when we try and publish something to the relational data datastore, I get the following error in the logs.
<Msg time="2023-07-03T14:47:58,68" type="SEVERE" code="6563" source="Admin" process="2124" thread="1" methodName="" machine="HOSTNAME" user="" elapsed="" requestID="b5329cda-1553-4465-af04-60c117cc634e">Failed to create the service 'Hosted/Layer_1.FeatureServer'. null</Msg>
<Msg time="2023-07-03T14:47:58,68" type="DEBUG" code="9999" source="Admin" process="2124" thread="1" methodName="" machine="HOSTNAME" user="" elapsed="" requestID="b5329cda-1553-4465-af04-60c117cc634e">com.esri.sds.util.JavaSDSException
Creating a new tile cache in the datastore work, and we can also use the hosted tile cache services. So the error seems to be related to the relational data only.
Any thoughts on how I could troubleshoot more, or what might be the cause? I have attached the full error and Java crash from ArcGIS Server.
We installed the following patches last Friday.
https://support.esri.com/en-us/patches-updates/2023/arcgis-web-adaptor-iis-11-1-reliability-patch
https://support.esri.com/en-us/patches-updates/2023/arcgis-server-11-1-map-service-and-custom-data-feeds-patch
https://support.esri.com/en-us/patches-updates/2023/portal-for-arcgis-enterprise-sites-security-patch
ArcGIS Server 11.1.42869
ArcGIS Portal 11.1.42869
ArcGIS Datastore 11.1.42869
ArcGIS Webadaptor 11.1.42869
ArcGIS Webstyles 11.1.42869
Regards, Tony
