Hi, trying to think of a way for our users to be able to visually see and measure using a 50km diameter circular polygon.
I've had a play with the buffer tool, but it creates too many polygons which overlap/dissolve if I use our point set data.
Ideally our users would be able to move a 50km polygon which they can position on the map where they need to, or position the map underneath it. It will be used to measure fires within the 50km radius of a point, or measure all the points within the 50km radius of a particular fire/ fire front.
Any suggestions appreciated. Thanks.
