(do others get tired of having to google every issue in ArcGIS Pro? Man, it's exhausing!)
Today's issue is that I am writing a label expression in ArcGIS Pro using VBScript. I want to use a carriage return (or new line feed or whatever we're calling it) but the following do not work:
[map_label] & vbcr & [start_even]
[map_label] & vbcrlf & [start_even]
Also tried: $feature.map_label + "/n" + $feature.start_even
And: $feature.map_label + TextFormatting.NewLine + $feature.start_even
The expression check is valid. I'm using Pro 2.9.5.
Everything stays on the same line as seen below. HELP!
