Good morning Community,
I have been working with ArcGIS for a number of year but have only just started to venture into creating my own more complicated content. Specifically survey forms and asset inspection reports.
I am using Field Maps to create a asset inspection reporting system. My result is to change the symbology based on if the asset has been inspected. I have already defined a symbology that needs to be viewed by the field workers.
The solution to this is to create a new field with a concatenated input and define the symbology based on this. I have the following fields;
$feature.CUT_REGIME
$feature.Parcel_State
I would like the end result to read
$feature.CUT_REGIME ' - ' $feature.Parcel_State
if $feature.Parcel_State is blank/empty then I would like it to read 'incomplete'
I see that this may be a simple piece of Arcade for someone and would really appreciate some help.
Thanks very much.
At the moment i have managed to put the following together but it is not working.
Concatenate($feature.CUT_REGIME,
IsEmpty(
// Returns true(' - ','Incomplete')
// Returns false(' - ',$feature.Parce_State')
