I have been working with custom layouts and have run into an issue. If the screen size is transitioned (i.e. “Large screen device” to “Medium screen device”), each widget’s constructor is recalled and the state is reset. For example, if a user has set up a field to filter by in the Filter widget and the screen device is changed, the field is reset:
This affects OOTB custom widgets alike. The same issue occurs for switching the map widget to fullscreen.
Are there any reasonable workarounds to this? Does Esri plan to address this issue?
Thank you,
Jacob
