For all the rest of the graphic types in this example: Editing tools | ArcGIS API for JavaScript there are handles that indicate that the element is selected. If I add a simple point to the map, when you select it, it has no handles or highlight to indicate to the user that they have selected it. This almost seems like a oversight, since generally when you select something that is editable, there is something that changes to show you which feature you've selected.
What suggestions does the forum have to create a highlight that looks good and will be tied to the graphic when you move it so you haven't left it behind when you edit?
