Hello all,
I have several layers, about 7 in total, that display different location points of various types of wells across all 50 states. My boss only wants to see the locations of wells in certain areas of each state, with a separate arcgis online map for each view. I have a layers that defines boundaries of interest.
In arcgis pro , I can right-click the map, choose properties, choose "clip layers" and set my boundary layer as the clipping layer for all layers at once. Which is fantastic!
However, when I share this map with Arcgis online, ArcGIS online isn't preserving only showing items within my clip layer extent. Instead, it is showing all possible data for each layer, so I have wells appearing in all 50 states.
Does Arcgis online not have the option to clip all layers in a map at once as I can in Arcgis pro? Or is there an alternate way to do this Arcgis online?
The best way to visualize this in your mind is to think of a map that displays different types of wells, gas well, oil well, water well, etc, are across the USA, and he wants a map that shows what wells are only in a specific area in Florida. Then a separate map with well locations in a specific area in Georgia, and many more maps following the same logic. Each of these maps needs to be in Arcgis Online. Any thoughts on how to do this?
As I said I can do it perfectly in Arcgis Pro using the "Clip Layer" tool but I am having no luck in Arcgis online. I looked at "Layer views" in arcgis online and thought that might give me the desired result, but I can only see how to clip by a layer's attribute, not how to clip by a secondary layer's outline. Am I doing something wrong here?
Any help would be great!
