This documentation says I should be able to pass in resultRecordCount as an argument when querying a feature service. However when I try that with the below request:
curl 'https://REDACTED/arcgis/rest/services/REDACTED/REDACTED/FeatureServer/query?layerDefs=%5B%7B%22layerId%22%3A0%2C%22where%22%3A%221%3D1%22%7D%5D&geometry=&geometryType=esriGeometryEnvelope&inSR=&spatialRel=esriSpatialRelIntersects&time=&outSR=&havingClause=&gdbVersion=&historicMoment=&returnDistinctValues=false&returnGeometry=false&maxAllowableOffset=&returnIdsOnly=false&returnCountOnly=false&returnZ=false&returnM=false&geometryPrecision=&multipatchOption=xyFootprint&returnTrueCurves=false&resultOffset=&resultRecordCount=1&sqlFormat=none&f=pjson'
I get the response:
"error": {
"code": 400,
"message": "Unable to complete operation.",
"details": [
"Unable to perform query."
The server logs say:
Error: Invalid pagination clause specified. First specify order by clause, then pagination clause. .
Unfortunately there is no option to pass an order by clause using the web interface
and if I try to pass it manually using the convention specified in the documentation it has no effect.
curl 'https://REDACTED/arcgis/rest/services/REDACTED/REDACTED/FeatureServer/query?layerDefs=%5B%7B%22layerId%22%3A0%2C%22where%22%3A%221%3D1%22%2C%22resultRecordCount%22%3A1%7D%5D&geometry=&geometryType=esriGeometryEnvelope&inSR=&spatialRel=esriSpatialRelIntersects&time=&outSR=&havingClause=&gdbVersion=&historicMoment=&returnDistinctValues=false&returnGeometry=false&maxAllowableOffset=&returnIdsOnly=false&returnCountOnly=false&returnZ=false&returnM=false&geometryPrecision=&multipatchOption=xyFootprint&returnTrueCurves=false&resultOffset=&resultRecordCount=1&sqlFormat=none&f=pjson&orderByFields=objectd'
Response:
"error": {
"code": 400,
"details": [
I am using ArcGIS enterprise 10.81
