This is a multi-part question:
1. We have users editing a COGO-enabled line feature class in SDE with some using ArcMap and others Pro. The COGO fields were initially created in ArcMap and are text and do not populate in Pro. I understand Pro needs these fields to be double. We want to leave these fields alone for the time being. As a work around we created fields named Pro_Direction, Pro_Distance, Pro_Radius, Pro_ArcLength, and Pro_Radius2. When I enter my COGO lines, I then run calculate geometry on the Pro_Direction field and it is changing my bearing from what the legal description states. I suspect this is because Pro is forcing the traverse to close thereby altering the bearing, although I am not sure.
2. Is there a way to turn off this force closure? When I begin entering the traverse, force closure is not checked; however, by the time I reach the last call it becomes checked.
3. Is there away to use the Update COGO tool to run on my new fields rather than the old ArcMap fields which it will not work on?
I am looking for a work around to keep my old ArcMap fields but populate these new fields with the correct bearing that I actually enter that matches the legal description.
I am attaching a screenshot of the actual bearings I entered and how they changed when I ran calculate geometry and a screenshot from the calculate geometry.
