I finally have my offline map areas working properly, after several versions and over an hour on the phone with Esri tech support. It's been a bit of a nightmare. While I'm happy that we seem to be able to use field maps, I noticed that the attribute fields are in a different order in the offline map area than they are in the attribute table. The order they are now in is not in the direction of flow for our work. Has this happened to anybody else? Any ideas on how to change the order in the offline map area?
