I'm trying to complete a spatial join between US Postal Service zip codes and US Census ZCTAs. Zip codes and ZCTAs do not perfectly overlap, and many overlap quite a bit. I used the Spatial Join tool and the "Largest Overlap" relationship, and want an output that gives me the zip code and its ZCTA that overlaps it the most. But, when I run it, the consistent result is a mismatch between the Zip Codes and their ZCTAs (I figured this out by visually double checking). Instead, the tool aligns the zip code to a ZCTA that has a very small overlap with the zip code, rather than the zip code with the most overlap (see pics attached).
I've ensured the layers are in the same gdb, the projections are the same, and the geometries are solid. I've tried ESRI's suggested solve for a similar question (Intersect and then Summarize Within). Results remain misaligned. I've successfully used the Largest Overlap relationship for a separate project, but can't get it right for this one. Please help -- thank you!
