I'm trying to run a weighted overlay on two separate integer rasters. I built the original overlay model in arcpro and exported the tool as script. I then modified the script to fit the syntax as shown on the ESRI help pages. Now when I run the script I receive (Unspecified error Class not registered). The landcover and slopeint classes reference existing raster files in the environment gdb. I have cropped out the middle portion of the script that prepares the rasters.
What did I do wrong?
#Import modules
import arcpy
from arcpy.sa import *
from sys import argv
LandCover = "LandCover"
slopeint = "slopeint"
intable = WOTable([[slopeint, 50, "Value", RemapValue([[0, 3], [1, 3], [2, 3], [3, 3], [4, 3], [5, 3], [6, 3], [7, 3], [8, 3], [9, 3], [10, 3], [11, 3], [12, 3], [13, 2], [14, 2], [15, 1], [16, 'Restricted'], [17, 'Restricted'], [18, 'Restricted'], [19, 'Restricted'], [21, 'Restricted'], [22, 'Restricted'], [23, 'Restricted'], [24, 'Restricted'], ["NODATA", "NODATA"]])],
[LandCover, 50, "Class", RemapValue([['Open Water', 'Restricted'], ['Perennial Snow/Ice', 1], ['Developed, Open Space', 3], ['Developed, Low Intensity', 2], ['Developed, Medium Intensity', 1], ['Developed, High Intensity', 'Restricted'], ['Barren Land', 3], ['Deciduous Forest', 'Restricted'], ['Evergreen Forest', 'Restricted'], ['Mixed Forest', 'Restricted'], ['Shrub/Scrub', 2], ['Herbaceuous', 2], ['Hay/Pasture', 3], ['Cultivated Crops', 3], ['Woody Wetlands', 'Restricted'], ['Emergent Herbaceuous Wetlands', 'Restricted'], ['NODATA', 'NODATA']])]],
[1, 3, 1])
helicoptersuitability = WeightedOverlay(intable)
helicoptersuitability.save("helicoptersuitability")Error Message:
File "D:\Documents\School\USC\586\586_Project_5\Project_5\SiteSuitability.py", line 78, in <module>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\sa\Functions.py", line 10452, in WeightedOverlay
return Wrapper(
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\sa\Utils.py", line 55, in swapper
result = wrapper(*args, **kwargs)
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\sa\Functions.py", line 10449, in Wrapper
result = arcpy.sa.Apply(rasters, "WeightedOverlay", args)
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\ia\_ia.py", line 135, in Apply
return arcgisscripting._ia.Apply(in_raster=in_raster,
RuntimeError: Failed to apply Raster Function: 'WeightedOverlay' (Unspecified error
