I'm using arcpy, teaching myself so apologies for my code!
I want the update cursor to input the number of selected rows from a feature class into the score field of another using this code. It all seems to be working apart from the selection is not being honoured, I'm expecting to see a raw score of 1 and actually I'm getting 879.
# -*- coding: utf-8 -*-
Generated by ArcGIS ModelBuilder on : 2022-11-14 10:26:09
import arcpy
# Set environments
arcpy.env.workspace = r"c:\Users\CVSmith\OneDrive - Fauna & Flora International\Projects\ENI_HBRA\projects\ENI_HBRA_Scratch\HBRA_Scratch.gdb"
def Model1(): # Model1
# To allow overwriting outputs change overwriteOutput option to True.
arcpy.ImportToolbox(r"c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Data Management Tools.tbx")
CulturalSites = r"c:\Users\CVSmith\OneDrive - Fauna & Flora International\Projects\ENI_HBRA\datasets\HBRA_data\whc_sites_2021_CulturalBuffer_MLW.shp"
AU_Test = "AU_FR"
# Process: Select Layer By Location (Select Layer By Location) (management)
CulturalSites = arcpy.management.SelectLayerByLocation(CulturalSites, "INTERSECT", AU_Test, "", "NEW_SELECTION", "NOT_INVERT")
# Add Fields for scoring
arcpy.management.AddFields(AU_Test, [['F2_Raw', 'SHORT'], ['F2_Score','LONG']])
# Count number of intersecting features for F2_Raw score using Update cursor and Get Count
fields = ['F2_Raw']
with arcpy.da.UpdateCursor(AU_Test,fields) as cursor:
for row in cursor:
row[0] = int(arcpy.GetCount_management(CulturalSites).getOutput(0))
cursor.updateRow(row)
del row
# Process: Calculate Field (2) (Calculate Field) (management)
arcpy.management.CalculateField(AU_Test, "F2_Score", "Score(!F2_Score!,!F2_Raw!)", "PYTHON3", """def Score(F2_Score,F2_Raw):
if (F2_Raw > 0):
return 5
else:
return 1""", "TEXT", "NO_ENFORCE_DOMAINS")
if __name__ == '__main__':
# Global Environment settings
with arcpy.EnvManager(scratchWorkspace=r"c:\Users\CVSmith\OneDrive - Fauna & Flora International\Projects\ENI_HBRA\projects\ENI_HBRA_Scratch\HBRA_Scratch.gdb", workspace=r"c:\Users\CVSmith\OneDrive - Fauna & Flora International\Projects\ENI_HBRA\projects\ENI_HBRA_Scratch\HBRA_Scratch.gdb"):
Model1()
